Resistor bridge calculations ?
Discussion in 'Homework Help' started by curry87, Dec 22, 2010.
  1. curry87
    May 30, 2010
    101
    Need some help to solve the following resistor problems.
    First for resistor map 1(first figure)
    How do i calculate the current going though r5 ?
    So far i know the voltage between:
    vr13 is 5.5v
    vr24 is 1.7v
    For resistor map 2 (second figure)
    What steps are reqired to calculate the current going though r5 or r6 or r7 and the equivalent resistance?
  2. Jony130
    Feb 17, 2009
    3,995
    1,117
  3. Jony130
    Feb 17, 2009
    3,995
    1,117
    And of course you could use nodal analysis.
    (Vcc - Va) /R1 = (Va - Vb) / R5 + Va/ R3 (1)
    (Vcc - Vb) / R2 + (Va - Vb) / R5 - Vb/ R4 = 0 (2)
    IR5 = (Va - VB)/ R5
    IR5 = 393.30633uA
      File size:
      35.5 KB
      15
      File size:
      6.1 KB
      12
  4. curry87
    May 30, 2010
    101
    A little lost in the calculations for va and vb on figure 1 can you please break them down and explain exactly how to calculate them step by step my electrical theory knowledge is limited?
    If i find the voltage at node a and node b using the voltage divider calculation (r2/r1+r2)*vcc then subtracting b from a and dividing that by r5 why doesnt it come up with the same answer as using nodal analysis to find current though R5 ?
  5. Jony130
    Feb 17, 2009
    3,995
    1,117
    OK, let's try something simpler Thévenin's theorem
    http://en.wikipedia.org/wiki/Thévenin's_theorem
    So first step is to find Vth ( Va - Vb ) without R5
    Va = Vcc * R3 / (R1 + R3) = 5.53846154V
    Vb = Vcc * R4 / (R2 + R4) = 1.7027027V
    So Vth = ( Va - Vb) = 3.83575884V
    The next step is to find Rth looking into Va; Vb
    Rth = R1||R3 + R2||R4 = 3.07692308KΩ + 5.67567568KΩ = 8.75259876KΩ
    So finally we end with this simple diagram
    IR5 = Vth/(Rth + R5) = 392uA
    And if you add R6 and R7 there is now problem becaues those resistor are connect parallel to R1 and R7 parallel to R4.
    So when finding Vht then
    R1 = R1||R6
    R4 = R4||R7
    And of course you can directly determine IR5 from nodal analysis
    I use Mathematica software to do all the math for me.
  6. curry87
    May 30, 2010
    101
    How do you find Ir1,Ir2 when r5 is connected ive tried (vcc-va)/r1 and (vcc-vb)/r2 but doesn't give me the values that the simulation comes up with ?
    Is IT= ir1 + ir2 or ir3 +ir4 ?
  7. Jony130
    Feb 17, 2009
    3,995
    1,117
    Witch equation you use to find Va and Vb ?
  8. curry87
    May 30, 2010
    101
    The voltage divider eq for r1,r3 then r2,r4 .
  9. Jony130
    Feb 17, 2009
    3,995
    1,117
    You must understand that this equations
    Holds only when R5 is disconnect form the circuit.
    And I use this equations only for find Thevenin equivalent circuit (Vth).
    Becaues there is no simply way to find IR5 current.
    And I give you equations for Va, Vb and I5 when R5 is connect to the circuit.
    http://images.elektroda.net/54_1293045055.png
    And of course you could use Δ-Y transform to find Va and Vb
      File size:
      36.8 KB
      14
