Resistive?
Discussion in 'General Electronics Chat' started by anon34, May 14, 2013.
  1. anon34
    May 14, 2013
    How can I tell if an IC is resistive or not?
    I'm looking at LTC4357 & UC2907.
    Thanks!
  2. studiot
    Nov 9, 2007
    5,005
    515
    Welcome to all about circuits.
    What on earth, or a pc board, do you mean?
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    Are you referring to the output resistance of the device?
  4. tshuck
    Oct 18, 2012
    3,531
    675
    I think the OP wants to model an IC as a resistor. ICs typically have non-linear characteristics.
  5. #12
    Nov 30, 2010
    16,704
    7,351
    I would say an IC can be modeled as a resistive load, as compared to capacitive or inductive, but it can not be modeled as a single resistance value. The current changes as the IC does its job. In addition, some ICs deliver current to a load that might be capacitive or inductive, and that would make the circuit as a whole very different from only considering the IC.
