resister get burned
Discussion in 'General Electronics Chat' started by prakashkovaidt, Jan 2, 2015.
Thread Status:
Not open for further replies.
  1. prakashkovaidt
    Feb 4, 2014
    hai ,
    i've 5v 1A power supply, which is not working. reason is resistor get burned.
    its position is direct to AC line.
    Circuit:-
    ~L___________Bridge rectifier(Input 1)
    ~N____________Resister(Burned)______Bridge Rectifier(Input 2)
    i cant figure out resister value.fully burnt black
    Please tell me any idea about choosing right resister.
    I checked 10K and 1K resister . but dont know watt valve.
    im totally newbie for electronics. and this 4M.
    Thank you
  2. blocco a spirale
    Jun 18, 2008
    1,462
    370
    Do you think that the reason the resistor burnt out was, perhaps, due to a fault further down the line i.e. the problem is not a faulty resistor?
    Incidentally, no one knows what value the resistor (if it was a resistor) should be or what it's for.
    Since it is connected directly to the mains and putting the wrong device in could be dangerous; it is time for a new power supply.
  3. prakashkovaidt
    Feb 4, 2014
    Thanks G.
    I can see some burnt color code in resister.
    now i got another idea. surely i dont know this is correct
    the bridge rectifier have 2 AC inputs. may i connect direct AC to Bridge rectifier Input pin ,? is it right?
  4. blocco a spirale
    Jun 18, 2008
    1,462
    370
    No, it is not right.
    The resistor/unknown device was there for a reason, possibly over-current protection, in which case it has responded to an over-current situation (caused by a fault elsewhere in the power supply) by burning itself rather than burning your house down.
    Replace the power supply, there is nothing else to add.
  5. MrChips
    Oct 2, 2009
    12,652
    3,460
    Discussion of power supplies without proper AC mains transformer is against AAC rules.
    This thread is closed.
Thread Status:
