resistanse of LED
Discussion in 'General Electronics Chat' started by alimech, Dec 29, 2013.
  1. alimech
    Dec 29, 2013
    has LED resistor? if yes how much?
    i connect the 3v battery in led red 5mm and measure current.it would be 60mA.result is 3/60mA=47ohm.is that true?
  2. Ramussons
    May 3, 2013
    561
    92
    As far as I know, there is no "resistance" in LED's. Just like a diode, they have a voltage drop which varies with the current, upto a limit.
    In your experiment, the current is limited by the internal resistance of the cattery.
    Ramesh
    alimech likes this.
  3. MikeML
    Oct 2, 2009
    5,450
    1,066
    Here is a plot of the forward voltage V(f) [Red trace] of a typical Red LED as a function of current between 100uA and 30mA. Because LTSpice can do it, I also plotted V(f)/I(D1) [Green trace, units of Ohms]. What would you say the "resistance" of the LED is?
    alimech likes this.
  4. Austin Clark
    Dec 28, 2011
    409
    44
    I believe LED and diode resistance is roughly inversely proportional to voltage.
    Diodes has dynamic resistance. It's not constant.
    Try looking up incremental resistance.
  5. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    LED's have little to no resistance. You forgot to take the forward voltage drop into account. Look at your LED's datasheet, find the forward voltage, subtract it from the actual (measured) battery voltage, and you get (roughly) the internal resistance of the LED. It should be very low.
