resistances in parallel
Discussion in 'General Electronics Chat' started by sharanbr123, Oct 16, 2014.
  1. sharanbr123
    Sep 29, 2014
    49
    two resistances (R1, R2) in parallel can be replaced by a single resistance of value
    R = R1R2/R2+R2. Is this correct?
  2. djsfantasi
    Apr 11, 2010
    2,911
    881
    Double check what you wrote. My guess is that you made a simple typo.
    Second, the way you write the equation is ambiguous. Is the denominator just R2, or is it (as you entered) R2+R2? The use of parentheses might be called for here.
  3. sharanbr123
    Sep 29, 2014
    49
    oh, did I? Is it not (R1*R2)/(R1+R2)?
  4. tshuck
    Oct 18, 2012
    3,531
    675
    It is, but that is not what you originally wrote (and why it was suggested as a typo).
    You can also use the [​IMG]
    form (shown for 3 resistors in parallel, but this can be expanded for any number of parallel resistors).
  5. MrChips
    Oct 2, 2009
    12,648
    3,458
    Rather than trying to memorize any formula for resistances in series or parallel all you have to recall is:
    For resistances in series, you add resistance.
    For resistances in parallel, you add conductance.
    ...which ought to be intuitive.
    Šamaš-šum-ûkīn and tshuck like this.
  6. sharanbr123
    Sep 29, 2014
    49
    Thanks. djsfantasi wrote that I had a typo and also missing parenthesis. I wanted to make sure missing "*" was the typo since I assumed that it was self explanatory in the given context.
  7. tshuck
    Oct 18, 2012
    3,531
    675
    No, your denominator equates to 2*R2... The '*' is typically omitted when the intent is clear.
  8. djsfantasi
    Apr 11, 2010
    2,911
    881
    I assume that by now you discovered what I saw as a "typo". In post #3, you wrote the equation correctly and unambiguously. You had repeated R2, (R2+R2), instead of (R1+R2). And the parentheses was necessary to clearly show you intended to divide by the sum.
    I'd write out what the original mistaken equation implied, but won't for fear it will only confuse things more. Suffice it to say tat your equation in post #3 is correct.
  9. Šamaš-šum-ûkīn
    Oct 10, 2014
    13
    Oh, this how the reverse 1/R is called. Nice. +1
  10. MrChips
    Oct 2, 2009
    12,648
    3,458
    Yes.
    Conductivity = 1/resistivity
    Conductance = 1/resistance
  11. alfacliff
    Dec 13, 2013
    2,449
    428
    and remember, for resistances in paralell, the total will alwways be lower than the lowest value.
