Resistance Wire (Kanthal A1) vs Copper Wire
Discussion in 'General Electronics Chat' started by Guest3123, Jan 4, 2016.
  1. Guest3123
    Oct 28, 2014
    334
    18
    The Copper Wire (PVC Stranded Wire)
    Length : 9.6899 Feet
    Resistance : 1.000Ω
    Gauge : 30AWG
    Ω/Ft : 0.1641
    The Kanthal A1 Resistance Wire..
    Length : 36.3mm, or.. 1.429 Inches
    Resistance : 1.000Ω
    Gauge : 30AWG
    Ω/Ft : 8.36
    The Copper Wire
    The longer the Copper wire, the more hotter it gets.. The shortter the copper wire, the less hotter it gets. Shorter runs usually have less voltage drop, etc. etc.
    The longer the run piece of wire, the cooler it becomes. I should know, I build coils for my RDA for my Box Mod. The Shorter the wire.. WATCH OUT !! Because if it's too short, when you press the button, it will vaporize the wire.
    I have a Box mod, and I use this stuff all the time. day in, and day out. I have made decent Windows Apps programed in Visual Basic .NET.
    Why does Resistance Wire behave differently than Copper wire?
  2. Guest3123
    Oct 28, 2014
    334
    18
    But yet, a Short piece of copper wire wont vaporize, like the Kanthal A1 Resistance wire..
    In fact, that's a good thing.
    The Resistance of a 1 Inch piece of 30AWG Copper Wire is..
    0.1641Ω Per Foot, so simply divide by 12"
    0.1641 / 12 = 0.013675Ω, so no resistance.
    The Resistance of a 1 Inch piece of 30AWG Kanthal A1 Resistance Wire is..
    8.36Ω Per Foot, so simple divide by 12"
    8.36 / 12 = 0.696666Ω, so almost 7/10th of an Ohm.
    Regardless of what I just put in the above text. The longer the kanthal wire, the cooler it will get when creating a heating element, or shorting it between Positive and Negative on a LiPo 2S, 130C, 3,500mAh Battery.
    Regardless of what I just put in the above text. The longer the copper wire, the hotter it will get when creating a heating element, or shorting it between Positive and Negative on the LiPo 2S, 130C, 3,500mAh Battery.
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    It doesn't.
    The only difference is the length of wire at which your various observations happen.
    But for a given resistance, a longer copper wire can carry more current without overheating since it has more area to dissipate the heat generated.
    You observations about copper wire don't make sense.
    A longer wire (either resistance type or copper) will have more resistance and run cooler for a given voltage across it. :confused:
    Guest3123 likes this.
  4. Guest3123
    Oct 28, 2014
    334
    18
    The Copper wire has more resistance, Ohms law.
    1 Inch of 30AWG Copper wire is 0.013675Ω, 1828.15 Watts, 365.63 Amps, 5V DC.
    The Kanthal wire has less resistance, Ohms law.
    1 Inch of 30AWG Kanthal A1 Resistance wire is 0.696666Ω, 35.88 Watts, 7.17 Amps, 5V DC.
    Can someone please explain this?
    I know the video doesn't have anything to do with what I was asking. I also am aware now that what @CrutShow has said is true. But please tell me what is going on in the video I've listed in the above text. The copper wire has a much less resistance, but yet...
  5. Guest3123
    Oct 28, 2014
    334
    18
    If I made a 2.7Ω Kanthal wire, and passed 12vdc threw it, it would heat up. It would be 12vdc, 2.7Ω, 4.44A, 53.33 Watts.
    If I made a 0.1Ohm Copper wire, and passed 12vdc threw it, it would heat up. It would be 12vdc, 0.1Ω, 120A, 1,440 Watts (1.44kW)
    What is going on..?
    Is it because the two wires are in series, and connected to each other? Wouldn't the Copper wire burn the paper first if they weren't connected to each other?
  6. SLK001
    Nov 29, 2011
    851
    243
    ALL wire will heat up if you pass current through it.
    It confuses you that a wire dissipating 1.44 kWatt of power is heating up? Likewise, a wire dissipating 53 Watts also?
    What is going on...? It's simple - OHM's law is going on.
  7. Lestraveled
    May 19, 2014
    1,957
    1,218
    Your more and less are reversed. 0.013675Ω is less than 0.696666Ω.
    Guest3123 and cmartinez like this.
  8. BR-549
    Sep 22, 2013
    2,181
    419
    I agree with the video. You are seeing the effect of resistance. That's what resistance does.
    It produces heat. The amount of heat depends on the amount of resistance.
  9. Lestraveled
    May 19, 2014
    1,957
    1,218
    There is a simple formula to calculate dissipated heat, Watt = Current squared time resistance. In the video, the two resistances are in series and thus have the same current. The wire with the highest resistance will dissipate the highest heat.
  10. crutschow
    Mar 14, 2008
    13,501
    3,375
    What's going on is the difference between serial and parallel circuits.
    In series the current is limited by the high resistance of the Kanthal or nichrome wire so most of the voltage drop (and power) is across the high resistance wire and not the copper wire (that's how a space heater works in your house).
    If you connect the two wires separately (in parallel) to the same battery then the current through the copper wire would be much higher and it would dissipate much more power as per V^2 / R (as would occur if you short circuited the mains socket in your house). :eek:
  11. Guest3123
    Oct 28, 2014
    334
    18
    So it's the path of least resistance. Even though the copper wire was 0.1Ω
    0.1Ω is MORE resistance, AND 2.7Ω is LESS resistance.
    The 12V DC passed thru the path of LESS resistance.
    Even though that Ohms law states that 1440kW should have been dissipated thru the Copper wire, which according to Ohms Law, is 12vdc, 0.1Ω, 120A, and again, should have dissipated 1.44kW.
  12. Lestraveled
    May 19, 2014
    1,957
    1,218
    @Guest3123
    No, you are not getting it. I don't think you understand how current works in parallel and series circuits.
    Read the section on series and parallel circuits, but for now think about this:
    - If you have two different resistors in parallel, the voltage on each resistor will be the same but the current will be different.
    - If you put the same two resistors in series, the current through each resistor will be the same but the voltage will be different.
  13. GopherT
    Nov 23, 2012
    6,314
    4,033
    Dude,
    The current is calculated by Adding the resistance of Kanthal (2.7) and copper (0.1) and call that R. V= 12 volts.
    Then current (I) is V/R. 12/2.8 = 4.286 amps
    Now, to calculate voltage drop across the copper wire snd the voltage drop across the Kanthal, multiply the 4.286 amps by the resistance of the copper and the resistance of the Kanthal. See answers in pictures below. Notice that the total voltage adds to 12.
  14. Guest3123
    Oct 28, 2014
    334
    18
    Watching a video, and learning about it.
    I'll be back in about an hour or so.
    cmartinez and GopherT like this.
  15. BR-549
    Sep 22, 2013
    2,181
    419
    Gopher meant 4.286 amps., not ohms, in his calculation explanation.
    GopherT likes this.
  16. Guest3123
    Oct 28, 2014
    334
    18
    Just watched a video..
  17. Guest3123
    Oct 28, 2014
    334
    18
    Where do you get 100mOhms from? It's 0.1Ohms. That's 1/10th of an Ohm. It's not 1.837 Watts. It's 12V² / 0.1Ω = ((12v x 12v) / 0.1Ω = 1,440 Watts.
    But it's not.. It's (0.428V * 0.428V) / 0.1Ω = 1.83184 Watts.
    Ok ok.. I got this now.. Your right. lol.
    (11.556V * 11.556V) / 2.7Ω = 49.45968 Watts.. Well I'll be damned.. It's true.
    Yes I know my precision is off.
    Here let's fix that.
    4.2857142857142857142857142857143 Amps.
    4.2857142857142857142857142857143 Amps x 2.7Ω = 11.571428571428571428571428571429 Vdc
    4.2857142857142857142857142857143 Amps x 0.1Ω = 0.42857142857142857142857142857143 Vdc
    0.42857142857142857142857142857143Vdc + 11.571428571428571428571428571429Vdc = 12Vdc Exactly.
    Calculating the Precise Watts.
    0.42857142857142857142857142857143Vdc² / 0.1Ω = 1.8367346938775510204081632653061 Watts.
    11.571428571428571428571428571429Vdc² / 2.7Ω = 49.591836734693877551020408163269 Watts.
    God damn, it really does pay to study. Thanks for the help guys. I understand now, and I see what it going on.
    cmartinez likes this.
  18. Guest3123
    Oct 28, 2014
    334
    18
    Because like what @Lestraveled said..
    So, then I went and watched the video about Resistors in Series.. and VOLLA !! I payed attention, and learned exactly what Gopher posted.
    But instead of being given the answers, I actually understand what is going on in the first video, because I taught myself how to understand what the hell was going on. With the help of course of everyone that gave me direction.
    GopherT likes this.
  19. cmartinez
    Jan 17, 2007
    3,698
    2,788
    And that, my friend, is the very essence of this site.
    Glad you were able to figure things out on your own. Welcome aboard!
    Word of advice: don't stop here, there's plenty of other exciting stuff you can learn and do fun things with.
  20. GopherT
    Nov 23, 2012
    6,314
    4,033
    One piece of advice, after you write the first three digits that are not zeros. You can round everything else off as zeros. Just put the right number of zero until the decimal (or use appropriate prefix for to a avoid most zeros. Nice work plowing through it!
