Hi everyone. I am currently working on designing a circuit which will convert a resistance value to a voltage. The design of the circuit includes the use of a bridge rectifier and an op amp which will amplify the voltage difference between each side of the bridge. Designing the bridge is fairly easy, however designing the amplifier portion of the circuit is difficult so far. Does anyone have any suggestions on what approach I should take in designing the amplifier portion of the circuit?
Thanks!
Thanks!
