I try to make a simple electronic circuit.
So I have an instrument (medical ophtalmoscope) that contains a light bulb 10w, 6v. The adapter is noted 6v, 1.7A . I want to bypass the small rechargeable battery pack that isnt working well. So I want to dim my bulb using a potentiometer. I tried a 100kΩ that was smoking (I chose that resistance because that's what is noted on the potentiometer of my original batt pack . So I guess there was a more complex assembly of resistors connected to it.)
My question: what is the ideal resistance needed for my potentiometer in this circuit (and does it have to be linear or logarithmic) ? I want the brightness to vary ok but not necessarily perfect. (A range of acceptable resistances would be fine ). I want it to work without burning it this time.
Thanks a lot,
Thanks a lot,
