resistance soldering
Discussion in 'General Electronics Chat' started by electronis whiz, Aug 28, 2011.
  1. electronis whiz
    Jul 29, 2010
    519
    27
    i have a cold heat solder iron and some normal solder irons, can i make a bigger homemade cold heat? if i can hom many amps power supply and at what voltage should i use. for the electrodes for it can i just use #12 or 14 solid coper wire?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here's an article on how they work:
    http://science.howstuffworks.com/cold-heat.htm
    In my opinion, it wouldn't really be practical for someone to try to make a larger one at home.
    If you try to use solid copper wire and high current, you will most likely fry whatever components you're trying to solder.
    Weller makes, or used to make, soldering "guns" that used high AC current to heat a copper tip. These are not recommended for soldering electronic components, but I knew people who did. I personally would not use one for such purpose.
