resistance question
Discussion in 'General Electronics Chat' started by rfrenkel, Dec 17, 2009.
Thread Status:
Not open for further replies.
  1. rfrenkel
    Dec 17, 2009
    I need an audio cable with a resistance of less than 0.07 ohms and was told that the lower the number the higher the resistance-- is that accurate? The cable I have has a resistance of 0.12 ohms. Is that good or bad. Here is what the actual brochure said "High loop resistances that exceed 0.07Ω
    (for each wire run) will cause the filter
    network to be mis-terminated, resulting in
    considerable degradation of sound quality."
    Is this cable a problem for me?
  2. Duane P Wetick
    Apr 23, 2009
    408
    19
    You can use a 24 awg cable or a 12 awg cable and you won't be able to detect any difference in audio quality. So its your choice entirely.
    Regards, DPW [ Spent years making heaters out of op-amps.]
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I'm sorry - I meant to move the original post to this forum. I'll close this and move the other, as it has more replies.
Thread Status:
