Resistance of water detecting ground probes
Discussion in 'General Electronics Chat' started by pdc, Mar 11, 2013.
  1. pdc
    Mar 1, 2009
    10
    I've been trying to find a decent probe for detecting the "dryness" of a soil sample. Testing different probes in different soils, the best I have come up with is slim piece of wood sandwiched between a pair of aluminum plates, courtesy of a coke can. Long term, wood has issues, but it absorbs the moisture and registers a consistent resistance change. Pure metal based probes are hit and miss. Loose soils sometimes don't even register. Wood rots, metals corrodes, sponges and foams didn't work (at least the ones I tried), and even good old red pottery didn't work well (with the coke can sandwich. surprised a bit about that one). A bit curious if anyone has gone down a similar path.
    Basic project was an on demand hydroponic watering system. Design works, but the piece of wood thing seems short term (or perhaps genius, like HP print cartridges :).
    Thanks,
    Paul
  2. panic mode
    Oct 10, 2011
    1,329
    305
    well, you still didn't try capacitive approach
  3. PackratKing
    Jul 13, 2008
    850
    216
    ...and therein lies your solution...
  4. pdc
    Mar 1, 2009
    10
    Looks a bit more complicated, but would be an excuse to use one of my digisparks.
    Paul
