Resistance control mechanism in an oscillator
Discussion in 'The Projects Forum' started by keyser, Dec 16, 2009.
  1. keyser
    Dec 16, 2009
    I am doing a project on design of a quadrature oscillator and have been give a problem of assuming
    one of the resistance value to be variable(due to environmental factors) and to make a
    automatic controller for that resistance ... one of the things i have thought about is using a digital potentiometer
    but i am having trouble visualizing it in a practical circuit ... any insight on how to use digital pot as a
    resistance controller or any other ingenious ideas regarding automatic resistance control would be
    greatly appreciated ....
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Using a DPOT requires a microprocessor or some logic to change the setting. That may exceed the scope of the project.
    Google "thermistor". It is a device that changes its resistance with temperature.
    You can also look up "ldr", or "cds cell". The device changes resistance with changing light.
    You don't show the power sources - those old LM741's need +/- 15 volt supplies to operate correctly. We would probably recommend using a TL072 instead.
  3. keyser
    Dec 16, 2009
    Thanks but according to the problem we have to control the changes in resistance value due to any factor (not just temperature or light) so using thermistor or ldr will not solve the problem ..
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Sorry, I thought light and temperature were affected by the environment.
