resistance choosing help
Discussion in 'General Electronics Chat' started by bobparihar, Sep 17, 2014.
  1. bobparihar
    Jul 31, 2014
    93
    i need 750 k ohm resistance in my circuit..
    but i have not that resistance..
    can i use a 670 k ohm and 100k ohm in series to achieve that.. i know that the theory says resistance get added when connected in series.. does it practically works?
  2. #12
    Nov 30, 2010
    16,671
    7,314
    Yes, it really works. You only have to be careful that one resistor is not getting too hot by using P=IE to find the power in each resistor.
    bobparihar and Lundwall_Paul like this.
  3. bobparihar
    Jul 31, 2014
    93
    i need to connect 750k ohm resistance to the two pin(osc 1 and osc 2) of HT12E encoder IC.. would it work..?
  4. #12
    Nov 30, 2010
    16,671
    7,314
    All I get for HT12E is Chinese characters. Can you post a datasheet?
    bobparihar likes this.
  5. tom_s
    Member
    Jun 27, 2014
    287
    342
    or parallel 2 x 1.5m ohm
    bobparihar and GopherT like this.
  6. Lundwall_Paul
    Oct 18, 2011
    222
    19
    http://octopart.com/ Is an excellent source for data sheets. You will find the data sheet there for HT12E. I just looked at it.
    bobparihar and ISB123 like this.
  7. shteii01
    Feb 19, 2010
    3,500
    511
    Yes.
  8. crutschow
    Mar 14, 2008
    13,482
    3,370
    Yes, but it will give you 770k ohm, not 750k. Is that okay? A 670k and an 82K in series would be closer.
