Resistance and Current
Discussion in 'General Electronics Chat' started by De-alex, Aug 6, 2014.
  1. De-alex
    Aug 6, 2014
    So for school we have been measuring the resistance, volts and current of various kettles. In comparison with results from other kettles- i have gotten kettles with high resistance but also high amps. How exactly is this possible?
  2. GopherT
    Nov 23, 2012
    6,331
    4,081
    Kettles? Like an electric rice cooker or an actual kettle? I don't understand.
  3. De-alex
    Aug 6, 2014
    Kettles which boil water- for tea and coffee
  4. mitko89
    Member
    Sep 20, 2012
    123
    19
    Current of a kettle? You have discovered a kettle generator? Can you take a picutre of it.
  5. De-alex
    Aug 6, 2014
    Im just using a simple power saver deceive to measure the amps/voltage and an ammeter to measure the resistance.
  6. AlphaDesign888
    Jul 27, 2014
    189
    10
    Try doing it with incandesent light bulbs. You'll do your head in quicker.
    Dynamic resistance.
  7. alfacliff
    Dec 13, 2013
    2,449
    428
    the resistance changes as it heats up.
  8. crutschow
    Mar 14, 2008
    13,521
    3,388
    The cold resistance can be different than the hot resistance. Under what measurement conditions do you measure high resistance with a high current?
  9. wayneh
    Sep 9, 2010
    12,405
    3,255
    A "smart" kettle may use a triac for temperature control, and thus will not be always full on like a light bulb.
  10. crutschow
    Mar 14, 2008
    13,521
    3,388
    Good point. That would account for the high resistance with high amps with high resistance, since the triac would give a high resistance reading to an ohmmeter.
