Resettable Fuse
Discussion in 'General Electronics Chat' started by RodneyB, Oct 26, 2014.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    643
    13
    I have been testing a 1 Amp resettable fuse on a 12 Volt supply. The supply cuts off instantly when I put a dead short on the output. However I am worried that the resettable fuse gets VERY hot. How long will it last with a dead short?
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    What kind of resetable fuse are you using ?
    The polyfuse are working on heating by overcurrent .
    The heating will raise the resistance of the polyfuse .
    There are also mechanical resetable fuses .
    Bertus
    RodneyB likes this.
  3. #12
    Nov 30, 2010
    16,655
    7,293
    I found a shorted car door lock switch that had been under safety lock out with a polyfuse for months, and it was still working when I found the fault. So, there you are. These things can safely hold in overload condition for months.
    RodneyB likes this.
  4. RodneyB
    Apr 28, 2012
    643
    13
    Its a poly fuse
    I have attached the datasheet from the supplier
  5. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
  6. MrChips
    Oct 2, 2009
    12,622
    3,451
    The polyfuse will reach an equilibrium temperature and resistance where just the right amount of current conducts in order to maintain a given temperature.
