1. redtree
    Feb 3, 2014
    14
    I've got kind of a strange (I think) PIC programming issue.
    I'm coding a PIC16F1933 in assembly and have a power-up issue.
    When I build/program and reset my program things seem to work fine.
    If I remove the circuits main power (and leave the ICD3 connected), things still work fine. It's only when I COMPLETELY remove the PIC power sources, then the program does not seem to do what its supposed to.
    The steps seem to execute and the program is running, it just powers-up in the wrong state.
    How could this be different from a reset/clear power up state?
    How can reproduce this without the total removal of power?
    Thanks!
  2. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    Most of these issues IMHO come from not initializing variables... Simulators and ICD's initialize variables to 0.... So check if some variable isn't starting where you need it.
  3. embpic
    Member
    May 29, 2013
    187
    there may problem in hardware that is power supply post sch for more clear
  4. ErnieM
    Apr 24, 2011
    7,434
    1,625
    Are you running the debugger to see this? Uh-uh... that's a no-no. If you take power away you disturb the debugger state and generally need to reload the program.
    If you're not in debug mode... we need more input.
  5. redtree
    Feb 3, 2014
    14
    I'm checking the variable initialization now; we'll see.
    I'm running the program on the board independently (not in debug mode). But (until now) I've been leaving the ICD3 connected while running and testing and everything seemed happy. I only see and issue when I dis-connect the board power AND disconnect the ICD.
  6. tshuck
    Oct 18, 2012
    3,531
    675
    Could you post a schematic?
    Most programmers pull the reset (MCLR) high, and removing the programmer without a pullup (when MCLR is enabled) will cause issues similar to what you describe.
  7. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    Yeah! the reason I posted that was.. I have just done the exact same thing with a GLCD... The GLCD didn't initialize when stand alone.. but when I connected up to the debugger it ran fine... After assigning values to a couple of variables, it worked fine.....
  8. redtree
    Feb 3, 2014
    14
    thanks for the help.
    Looks like it was the initialization thing.
    I cleared EVERYTHING and it seems to work.
    Live and learn!
    ErnieM likes this.
  9. Markd77
    Sep 7, 2009
    2,803
    594
    I use the little loop that is in a lot of the datasheets to clear registers in almost all programs:
    Code ( (Unknown Language)):
    1.     MOVLW 0x20                  ;clear files
    2.     MOVWF FSR
    3. NEXT
    4.     CLRF INDF
    5.     INCF FSR, F
    6.     BTFSS FSR, 7
    7.     GOTO NEXT
    Obviously changing as required. Compared to the actual startup time of a PIC this is very quick.
