RESET button to MCU
Discussion in 'Programmer's Corner' started by Jaden5165, Sep 18, 2011.
  1. Jaden5165
    Sep 9, 2011
    69
  2. t06afre
    May 11, 2009
    5,939
    1,222
    Are your programmer connected. It take control over the MCLR pin. Try to disconnect the programmer. And see if that help
  3. upand_at_them
    May 15, 2010
    246
    29
    Is it running from 5V? I use a 4.7K or 10K pullup resistor on MCLR, 1K is a bit strong.
  4. Jaden5165
    Sep 9, 2011
    69
    ya.from 5v.but what do you mean 1k is a bit strong?not 10k stronger than 1k?
  5. Jaden5165
    Sep 9, 2011
    69
    my programmer is not connected.how?
  6. Jaden5165
    Sep 9, 2011
    69
    nobody can help?oh no!
  7. AlexR
    Jan 16, 2008
    735
    54
    It would help if you posted your code (use the "Go Advanced" button and wrap your code in the code tags "#" so that it easier to read. Without the code its hard to say what is going wrong.
    Jaden5165 likes this.
  8. stahta01
    Member
    Jun 9, 2011
    133
    21
    An 10K resistor only needs 1/10 the current of an 1k resistor to pull the voltage down to a low voltage.
    Note: No idea if that is the cause; I would guess I code issue; but, I am mainly a programer instead of a hardware person. So, I always look to eliminate what is easier for me to check. After checking the normal hardware things on PICs.
    Normal hardware Items to check.
    Note: I have seen PICs partly work without one of Power or Ground Pins connected.
    Ground to PIC
    Power to PIC
    MCLR properly connected; the proper connection can vary some per configuration options.
    If using external Crystal is it connected with the recommend capacitor(s)
    Check the rest of the schematic connections.
    Tim S.
  9. chejian6
    May 22, 2011
    10
    I think there're 3 things to do:
    1. change the pull-up res from 1k to 4.7k
    2. add a 1uf cap between MCLR and GND
    3. Make sure the load cap of the crystal is correct. Most load caps of crystal are from 10 to 20p. 30p may be a little bigger.
  10. upand_at_them
    May 15, 2010
    246
    29
    Think of it this way: If you have a 1 ohm resistor tying a pin to 5V you will not be able to pull it away from that 5V. But if a 10K ohm resistor is used you can easily pull it away from the 5V. Therefore, 1 ohm is "stronger" than 10k ohm.
  11. debjit625
    Apr 17, 2010
    790
    186
    The circuit is ok,it will work properly but your switch might cause the problem so buy good quality switch.I did the same mistake when I was starting with these stuffs...
    You can use this circuit for reset...
  12. nigelwright7557
    May 10, 2008
    488
    71
    I connect my /mclr to 5 volts !
  13. t06afre
    May 11, 2009
    5,939
    1,222
    Thenever I can (working with PICs) I disable the MCLR function.
  14. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Is it on a breadboard? It can be common to get a problem where the PIC xtal oscillator does not re-start after MCLR reset. Usually caused by long wires and/or too much capacitance near the xtal caused by the breadboard.
