Research About Transformers
Discussion in 'General Electronics Chat' started by MissLesette, Jan 8, 2013.
  1. MissLesette
    Sep 13, 2006
    In one mini project, a student requires to use a 110 Vac single-phase voltage supply to run his circuit from available single-phase voltage supply of 240 Vac. The circuit may draw a current not more than 8 A.
    Thanks for helping me... ;)
  2. crutschow
    Mar 14, 2008
    13,462
    3,353
    So it would appear this "student" needs a 240V to 110V (120V) transformer with a minimum 8A rating at the mains frequency. Those are sold by most transformer manufacturers. If you don't need isolation between the primary and secondary, an autotransformer with this rating would be the cheapest.
  3. MissLesette
    Sep 13, 2006
    Thanks Mr. Crutschow... although ur explaination was short but I can understand it very clearly... thanks a lot :)
