Requirement of different binary codes
Discussion in 'The Projects Forum' started by chintan_gaurav8, Aug 25, 2010.
  1. chintan_gaurav8
    Jul 27, 2009
    I want to know why there is requirement to represent digital value in different binary code such as excess-3, grey code, 8421 code etc. Wether we require these codes for some particular application?
  2. mik3
    Feb 4, 2008
    4,846
    63
    Because some codes work efficiently than others at some applications.
  3. DumboFixer
    Feb 10, 2009
    219
    34
    Grey code is useful as only 1 bit changes at a time (assuming linear change) so if you detect 2 bits have changed then you know you have an error. Often used for positional encoding on shafts (I believe)
