Require Test bench for PS2 keyboard
Discussion in 'General Electronics Chat' started by anirbanphys, Aug 2, 2009.
  1. anirbanphys
    Aug 1, 2009
    I've written a verilog code for PS2 keyboard, though a test bench is also there, but how an effective test bench can be written? Please help me......
    module ps2_ascii_input(clock_27mhz, reset, clock, data, notes_ready,
    notes);
    input clock_27mhz;
    input reset; // Active high asynchronous reset
    input clock; // PS/2 clock
    input data; // PS/2 data
    output notes_ready; // notes ready (one clock_27mhz cycle active high)
    output [1:0] notes; // notes of the musical scales
    reg [7:0] lastkey; // last keycode
    reg [7:0] curkey; // current keycode
    reg notes_ready; // synchronous one-cycle ready flag
    reg [1:0] notes; // the 2 notes of the keyboard
    reg brk = 0; // logic for whether or not a key is being released
    // get keycodes
    wire fifo_rd; // keyboard read request
    wire [7:0] fifo_data; // keyboard data
    wire fifo_empty; // flag: no keyboard data
    wire fifo_overflow; // keyboard data overflow
    ps2 myps2(reset, clock_27mhz, clock, data, fifo_rd, fifo_data,
    fifo_empty,fifo_overflow);
    assign fifo_rd = ~fifo_empty; // continous read
    reg key_ready;
    always @(posedge clock_27mhz) begin
    // get key if ready
    curkey <= ~fifo_empty ? fifo_data : curkey;
    lastkey <= ~fifo_empty ? curkey : lastkey;
    key_ready <= ~fifo_empty;
    // raise notes_ready for last key which was read
    notes_ready <= key_ready & ~(curkey[7]|lastkey[7]);
    case (curkey)
    8'h1c: begin notes[0] <= brk ? 0 :1; brk <= (lastkey == 8'hf0) ? brk : 0; end
    8'h1a: begin notes[1] <= brk ? 0 : 1; brk <= (lastkey == 8'hf0) ? brk : 0; end
    8'hf0: brk <= 1;
    default: begin notes <= notes; brk <= 0; end
    endcase // case(curkey)
    end // always @ (posedge clock_27mhz)
    endmodule // ps2toascii
    module ps2(reset, clock_27mhz, clock, data, fifo_rd, fifo_data,
    input clock_27mhz,reset;
    input data,clock; // ps2 data
    input fifo_rd; // fifo read request (active high)
    output [7:0] fifo_data; // fifo data output
    output fifo_empty; // fifo empty (active high)
    output fifo_overflow; // fifo overflow - too much kbd input
    reg [3:0] count; // count incoming data bits
    reg [9:0] shift; // accumulate incoming data bits
    reg [7:0] fifo[7:0]; // 8 element data fifo
    reg fifo_overflow;
    reg [2:0] wptr,rptr; // fifo write and read pointers
    wire [2:0] wptr_inc = wptr + 1;
    assign fifo_empty = (wptr == rptr);
    assign fifo_data = fifo[rptr];
    // synchronize PS2 clock to local clock and look for falling edge
    reg [2:0] ps2c_sync;
    always @ (posedge clock_27mhz) ps2c_sync <= {ps2c_sync[1:0],clock};
    wire sample = ps2c_sync[2] & ~ps2c_sync[1];
    always @ (posedge clock_27mhz) begin
    if (reset) begin
    count <= 0;
    wptr <= 0;
    rptr <= 0;
    fifo_overflow <= 0;
    end
    else if (sample) begin
    // order of arrival: 0,8 bits of data (LSB first),odd parity,1
    if (count==10) begin
    // just received what should be the stop bit
    if (shift[0]==0 && data==1 && (^shift[9:1])==1) begin
    fifo[wptr] <= shift[8:1];
    wptr <= wptr_inc;
    fifo_overflow <= fifo_overflow | (wptr_inc == rptr);
    end
    count <= 0;
    end else begin
    shift <= {data,shift[9:1]};
    count <= count + 1;
    end
    end
    // bump read pointer if we’re done with current value.
    // Read also resets the overflow indicator
    if (fifo_rd && !fifo_empty) begin
    rptr <= rptr + 1;
    fifo_overflow <= 0;
    end
    end
    endmodule
    module tb(clock_27mhz, reset, clock, data, notes_ready,
    notes);
    output reg clock_27mhz;
    output reg reset; // Active high asynchronous reset
    output reg clock; // PS/2 clock
    output reg data; // PS/2 data
    input wire notes_ready; // notes ready (one clock_27mhz cycle active high)
    input wire [1:0] notes; // notes of the musical scales
    ps2_ascii_input s1(clock_27mhz, reset, clock, data, notes_ready,
    notes);
    assign fifo_rd = 0;
    always
    #20 clock=~clock;
    always
    #3 clock_27mhz=~clock_27mhz;
    initial begin
    $monitor($time,,,"clock_27mhz=%b, reset=%b, clock=%b, data=%b, notes_ready=%b,notes=%b",clock_27mhz, reset, clock, data, notes_ready,notes);
    reset=1; clock=0; clock_27mhz=0; data=1;
    #6 data=0;#6 data=0;#6 data=0;#6 data=1;#6 data=1;#6 data=1;#6 data=0;#6 data=0;//mc
    #6 data=1;#6 data=1;#6 data=1;#6 data=1;#6 data=0;#6 data=0;#6 data=0;#6 data=0;//mc
    #0 $finish;
    end
    endmodule
