Once again both incredible films and yes I'm UK based I shall have a look for the components etc. The chip should be easy enough to programme
No one guessing? Well I'll start, even if it's bad.What? Its not magic?... Son of a b...
Whats next.. Please don't tell me Santa isn't real..
I do a "similar" trick.. But I look away and have them hold the hand with the coin in it against their forehead for about 20 seconds and tell them to "think" really hard about it..
Then I have them turn around and face me and then hold both hands out in front of them and I can guess which hand the coin is in EVERY time...
Anyone want to guess how that trick is possible?
Yep.. The hand with the coin is always "whiter/lighter" in color than the one without due to holding it above your heart..No one guessing? Well I'll start, even if it's bad.
• You may get some decreased blood flow from holding it against the forehead, the hand recovering from being held against their forehead
I wasn't exactly right, and I took a shotgun approach to solving it. That was going to bug me, thanks.Yep.. The hand with the coin is always "whiter/lighter" in color than the one without due to holding it above your heart..
Now that I think of it Magnoemeters are sensitive enough for the earths magnetic field and would easily be thrown off by a magnet nearby and they can do every axis, and they are MEMS (tiny) the problem then being modules are bigger, not design a custom PCB.Is there no way to programme a chip so not only does it sense the magnet but also senses the polarity? This meaning I don't need two sensors?
by Jeff Child
by Jeff Child
by Jake Hertz
by Jake Hertz
