request
Discussion in 'The Projects Forum' started by haroon642, Jun 3, 2011.
  1. haroon642
    Jun 3, 2011
    plzzzzzzzzz tell me the method to make light sensor switch operates on 220 volts with ciruit diagram and the material which i need
  2. DumboFixer
    Feb 10, 2009
    219
    34
    If you can't design something that simple, should you really be messing around with lethal voltages ?
    Try Google
  3. marshallf3
    Jul 26, 2010
    2,358
    201
    You simply buy or order one, a lot simpler, cheaper, reliable and safer than trying to do it yourself. If however you're stuck on trying to make one of your own that's what the Google search engine is for.
