Request help - does the same current flow in all secondaries of a transformer
Discussion in 'General Electronics Chat' started by iinself, Dec 8, 2015.
  1. iinself
    Jan 18, 2013
    69
    below is the circuit diagram of a old Pioneer receiver SX 1500. I am planning to reuse the transformer. In the picture (the thick black lines on the right top) pin 11 seems to be center tap and 13 and 9 are the other 2 ends of the winding. Between 11 and 13/9 I measure 33 V. But I don't need 33 V, all I need is about 18V which is what I measure between 12/10 and 11 the center tap. Can I use 12/10 with 11 for the PSU for a 50 W amplifier?
    The fuse rating for the old amplifier says 2.5 A and is designed for about 100 W. My doubt is is there any current limitation on the different secondaries of the same transformer or can all of them supply similar currents.
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Generally, they are different. You'll need to get a datasheet to find out what they are.
  3. Dodgydave
    Jun 22, 2012
    5,171
    778
    I would say yes, if you use the two diode full wave rectifier method (D601,602) like on the circuit of IC601 its got 23V input, (top right on circuit,) this method doubles the current of the transformer windings.
  4. iinself
    Jan 18, 2013
    69
    So I won't be able to power a bridge rectifier to get a dual +/- 24 to power about 50 W amp using the 12/10 and 11 the center tap ?
  5. umphrey
    Member
    Dec 1, 2012
    39
    If you can figure out the VA rating of the transformer you should be able to take it out of any tap combination you want
  6. hp1729
    Nov 23, 2015
    2,106
    235
    How big are the wires going to 10, 11,12? Are they the same size as 9 and 14?
  7. Dodgydave
    Jun 22, 2012
    5,171
    778
    The 24V tap is probably feeding the preamp and tuner section, so it wont need to be large, the 33V is for the power amp, that winding will have more current capability,
    Look at the transformer windings see if they are the same size.
  8. iinself
    Jan 18, 2013
    69
    Yes.
    Also when I measure resistance between them they all come to almost a short.
  9. MaxHeadRoom
    Jul 18, 2013
    10,870
    2,528
    You cannot use any single winding in order to utilize the max Va of the transformer without taking into consideration the current rating (gauge) of the winding you intend to use.
    Max.
  10. iinself
    Jan 18, 2013
    69
    I don't in terms of wire gauge but they are all the same size, even on the primary side from the mains the size is the same. Also all of the points 9 - 13 are show up as short ( < 1ohm) on the multimeter.
  11. iinself
    Jan 18, 2013
    69
    Ok. thanks.
  12. crutschow
    Mar 14, 2008
    13,523
    3,392
    Measuring the resistance of transformer windings is difficult because the resistance values are typically so small.
    A way to more accurately measure low resistances is to do a 4-wire measurement.
    If have a DC voltage supply, put a known current (say 1A) through the winding and measure the voltage drop directly across the winding leads. From that you can calculate the winding resistance using Ohm's law.
