Request guidance on calculating R values in this amp
Discussion in 'The Projects Forum' started by logans-electronics, Dec 5, 2009.
  1. logans-electronics
    Sep 1, 2009
    36
    I would like some guidance or advice on R1, R2, and R4 on how the are or should be calculated and the purpose of them.
    I have experimented in multisim with different values and this is the best I could get out of it.
    Thanks to forum member SGT WOOKIE for the starting point and template!:)
  2. logans-electronics
    Sep 1, 2009
    36
    Just wondering if anyone had a chance to review and offer some advice on how to calculate the resistor vales and the purpose of them...:confused:
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Embedding your schematics in a Word document makes it more difficult for people to read them; and many don't like to download such files because they can contain viruses.
    I've extracted your circuit and attached it in .png format.
    I've also attached a version that was posted previously.
    I don't have the transistors you used available in any simulators that I have installed.
    You have installed R5 backwards. The input signal can be shorted to ground if R5's resistance is turned way down. The signal input should be connected to the end of the pot furthest from ground, and the amplifier input taken from the wiper of the pot.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The values of R1, R2 and R4 are calculated from the max amount of base current you need for the transistors considering their minimum hFE.
  5. Jony130
    Feb 17, 2009
    3,993
    1,116
    Well, maybe this helps
    Vcc=Vr+Ve+Vbe+VL
    Vcc - supply voltage
    Vr - voltage drop on R1+R2
    VL - maximum voltage on the load (speaker)
    Ve- voltage on emitter (typical 0.5Vcc)
    then
    VL=√(2*Pout*RL)
    IL=VL/RL
    The maximum value of the load current is equal:
    IL_max = ( Vcc - Ve - Vbe ) / ( (R1+R2)/(β+1) + RL )
    then
    R1+R2=(\frac{Vcc-Ve-Vbe}{IL}-RL)*(\beta_{min}+1)
    For example
    Vcc=28V and output power Pout=7W; β_min=50; Vbe=0.7V
    VL=√(2*7W*6Ω)=9.2V
    IL=9.2V/6Ω=1.54A
    R1+R2=( ( 28V - 14V - 0.7V / 1.54A ) - 6Ω) * 51= 130Ω
    In the calculation I ignore the bootstrap circuit.
  6. logans-electronics
    Sep 1, 2009
    36
    This is making sense now....:)
    Did you mean that the bootstrapping is part of R4?.....I came up with this high value experimenting in Multisim and received the best results.:)
  7. logans-electronics
    Sep 1, 2009
    36
    Is the 51 a constant or a solved value from the circuit somewhere?
  8. Jony130
    Feb 17, 2009
    3,993
    1,116
    Bootstrap circuit is C3 and R2, R1
    51 is not a constant its a BJT minimum current gain β=Hfe=Ic/Ib
