Req problem
Discussion in 'Homework Help' started by freemindbmx, Mar 14, 2014.
  1. freemindbmx
    Mar 5, 2014
    72
    Me and a friend got stumped on this, any help would be great. But we need to find the Req at terminals A and B
  2. BytetoEat
    Mar 5, 2014
    25
    5
    it completely depends on what is going on with C and D!!!!
  3. WBahn
    Mar 31, 2012
    18,085
    4,917
    Perhaps you and your friend could show your best effort to find Req at terminals A and B?
    Perhaps start by bounding the possible results?
    What resistance can you guarantee the equivalent resistance will definitely be smaller than? What resistance can you guarantee the equivalent resistance will definitely be larger than than?
    At first glance you should be able to obtain a range that is less than a factor of two. A second glance should reduce that range to just a 1Ω.
    By bounding the problem, you then will know if your final answer is even possible (and even if you do it wrong and get a wrong answer, you will be close enough for most practical situations).
  4. shteii01
    Feb 19, 2010
    3,500
    511
    +1
    If C and D are not connected, open circuit, then 5 at C and 5 at D can be completely ignored.
    So you got 3 and 6 and 3 in series, call it R1. Then R1 is in parallel with 6, call it R2. Then R2 is in series with 5. BAM! You are done.
  5. freemindbmx
    Mar 5, 2014
    72
    C and D arn't connected to a load or anything just a open circuit like A and B
  6. freemindbmx
    Mar 5, 2014
    72
    Ahh me and my friend for some reason were thinking you short circuit C and D and like you said ignore it, thank you
  7. shteii01
    Feb 19, 2010
    3,500
    511
    If you short C and D, then there will be current through them when you connect something at AB. Following Ohm's Law, you have current, you have resistance, I*R=V, when you have the two, you have the third, the voltage. Therefore you can not simply ignore them if you short C and D.
    That is why the earlier question is so important. If CD is open, you have circuit with 5 resistors. If CD is closed, you have circuit with 7 resistors.
