Replacing voltage regulator tube with Zener diode
Discussion in 'Power Electronics' started by imke, Jun 24, 2016.
  1. imke
    Jun 24, 2016
    Bought a capacitor leakage tester, custom made, from ebay. Trying to replace two OB2 voltage regulator tubes (107 volts each) with two 110volt zener diodes, 5 watts, wired in series, and reverse biased, as required. Circuit stabilizes , after slowly climbing, at 238 volts; should be regulated at 220. Also, zeners are quite hot after several minutes. Any comments, or suggestions? Thanks.
    Mike
  2. DickCappels
    Aug 21, 2008
    2,756
    665
    I am sure the OB2 tubes got pretty hot too ;-) It seems your solution is workable.
    How much current is running through the Zeners?
    Can you post the schematic for us to look at?
  3. Veracohr
    Jan 3, 2011
    559
    77
    Is the current through the zeners the same that the voltage rating is specified at?
  4. imke
    Jun 24, 2016
    not sure; zeners are rated at 5 watts, compatible with tubes being replaced. Can check voltage drop across resistor to confirm.
  5. Bordodynov
    May 20, 2015
    670
    194
    Use a Zener diode cooling radiators.
  6. KeepItSimpleStupid
    Mar 4, 2014
    1,261
    222
