Replacing run capacitor
Discussion in 'General Electronics Chat' started by tanjera, Apr 7, 2011.
  1. tanjera
    Apr 7, 2011
    Hi All
    Please I need some advice!
    The run cap on my tumble drier exploded! It is labelled CBB61 7 micro farad 450VAC - The only replacement I could easily lay my hands on was a 8 micro farad unit at 450V.
    The drier now starts but runs for a while then stops for about 5 sec before it will start again.
    Hennie
  2. R!f@@
    Apr 2, 2009
    8,791
    771
    Check whether it is over heating. It could be a thermal switch inside tripping due to heat.
  3. tanjera
    Apr 7, 2011
    Thanks Riff that was indeed the problem!
    Hennie:D
  4. R!f@@
    Apr 2, 2009
    8,791
    771
    Ur Welcome...:)
    By the way do not bypass it, motor will burn. Check for the cause
