Replacing relay with chip for oscillating function
Discussion in 'General Electronics Chat' started by Jerry Dziuba, Apr 22, 2016.
  1. Jerry Dziuba
    Feb 18, 2016
    28
    I am currently using a mechanical relay to power an ignition coil to generate a spark by sending the power to the relay coil via one of the normally closed contacts. I'm guessing there is probably a better way to accomplish triggering the ignition coil, perhaps with some kind of chip?
  2. Dodgydave
    Jun 22, 2012
    5,130
    766
    If its low voltage dc use a mosfet.
  3. Alec_t
    Sep 17, 2013
    5,949
    1,129
    Googling "transistor ignition circuit" gives lots of examples.
  4. Jerry Dziuba
    Feb 18, 2016
    28
    Guess I should have mentioned it is 12vdc, so I should be good with that then.
