Quick question then??? Are these jumper connectors you see on pcb boards (see image below)+1 for Alec-t's idea....
You might try with 'Kynar' wire. (Like this: http://www.jameco.com/1/3/kynar-wire )
It's fiddly, but do-able... and much simpler than making a new pcb!
Let me once again show you that this is the part of the board that I need to repair and I've numbered & drawn in yellow where each lead is assigned to the corresponding pin of the 20pin plug. I bought a DJ Mixer from Amazon that wouldn't power up when I plugged it in. So clearly defective I got my $$$ back and I got to keep the mixer for FREE. So I opened it up & right away saw how messed up this area was. Turns out that this exact spot on the board carries power up from the sub assembly as well as audio in/out. So all I was looking for was the best solution toi utilize in my fix here and I'm considering just cutting this part of the board out & etching a new replacement part as it is a single sided pcb board, permanently affixing this newly etched piece to the board & then run fine copper wire from the remaining traces on the original board all 20 to their corresponding pin. Let me know if I need to be more clear in my explanation and images.I've done some pretty cracked up repairs with jumpers and some cleaning and re-do of the ground plane; but I have never seen this before at the TV repair shop?
Holy she - ite batman?
kv
Yeah that was just an image for example I've already got jumpers ready to go that are very malable.Yes, those are jumpers, but you will find them stiff and uncooperative. Much easier to use new copper wire than to unsolder a piece that is going to fight you.
Sweet deal MrChips and thanks to all of you who helped out a fellow Circuit Boardian if I can call it that. Well I'm off to perform some surgery on this board and I'll let you all know the outcome of this project and take care.In your case, the fiberglas board is sound.
I would just epoxy a connector to the board and run 30AWG wire-wrap wire from the pins to the traces.
Nah, I'm just taken back by the amount of work involved.Let me once again show you that this is the part of the board that I need to repair and I've numbered & drawn in yellow where each lead is assigned to the corresponding pin of the 20pin plug. I bought a DJ Mixer from Amazon that wouldn't power up when I plugged it in. So clearly defective I got my $$$ back and I got to keep the mixer for FREE. So I opened it up & right away saw how messed up this area was. Turns out that this exact spot on the board carries power up from the sub assembly as well as audio in/out. So all I was looking for was the best solution toi utilize in my fix here and I'm considering just cutting this part of the board out & etching a new replacement part as it is a single sided pcb board, permanently affixing this newly etched piece to the board & then run fine copper wire from the remaining traces on the original board all 20 to their corresponding pin. Let me know if I need to be more clear in my explanation and images.
They did plenty that were not there own, I'm trying to remember too! There was a Manufacture back then that had a real problem with burning. Might have been an RCA?I can't remember, but I'm sure it is not a secret. Probably on the Interwebs somewhere. If I remember, I'll come back here and post it.
One thing I do know, it couldn't have been Zenith. After 3 years with Sears, I got a job in a freelance shop. There was one TV that I couldn't quite get the color right. I eventually read the code dates in it and found it was 13 years old. No wonder I couldn't quite get it "right". A Sears TV would have been the trash can long before it got to 13 years old!
You haven't seen it at a TV repair shop because its not a TV. Its for a Professional Studio DJ Mixer.I've done some pretty cracked up repairs with jumpers and some cleaning and re-do of the ground plane; but I have never seen this before at the TV repair shop?
kv
I work with Clearone and have worked with Gentners the older version and both are the same just Clearone is updated version. It's Graphical Mixer; I am Certified by Clearone. Your are not going to see them in the local shop nor see them anywhere but inside Clearones manufacturing. I work for a University and Operate and Install plenty of Commercial Equipment.You haven't seen it at a TV repair shop because its not a TV. Its for a Professional Studio DJ Mixer.
RCA...Quasar..."Works in a drawer" That's what RCA was touting in the early 1970's.They did plenty that were not there own, I'm trying to remember too! There was a Manufacture back then that had a real problem with burning. Might have been an RCA?
