Hi every one .Is there any electronic circuit to replace the latching switches(push to /push to off)?
Yes.Hi every one .Is there any electronic circuit to replace the latching switches(push to /push to off)?
just i want to control one LED. 5v power is available.Yes.
What do you want to control with the push on / push off?
What power is available?
Thank you for u r reply @crustschow.Do you need it to come up in any particular state when the power is first applied?
Why not use a maintained P.B.?Thank you for u r reply @crustschow.
My requirement is when i press the push button(Tack tile ) led will ON.And if press once again Led will be in OFF state.
Thank you Crustschow.Circuit is working fine ,I checked with simulation. If i want to contol 7 leds with different 7 tactile switches ? For these i want to use single ic or 7 number of CD4013?Below is the LTspice simulation of an alternate action circuit which uses a CD4013 CMOS FF that changes state every time the push-button is pressed to alternately light the LED D1.
Hi MaxHeadRoom , thank you for u r reply . Presently iam using same (maintained P.B). I want to eliminate using of maintained P.B ,because some time mechanical switch will give problem. so i thought use simple tactile switch with latch circuit.Why not use a maintained P.B.?
Push on- Push off?
You can also do it with a relay circuit flip-flop using a momentary P.B..
Max.
Not if you use an industrial version, Telemecanique etc, and also if you wish to reduce any load on the switch contacts, a small simple relay would do it.I want to eliminate using of maintained P.B ,because some time mechanical switch will give problem. so i thought use simple tactile switch with latch circuit.
by Duane Benson
by Duane Benson
by Aaron Carman
by Jake Hertz
