I'm a beginner with electronics and plcs. I understand most electrical theory and components until I run it to circuit board and such. What I have is a bad npn inductive 3 wire switch that is normally open connected to a plc. What I was wondering if I was to connect a physically actuated switch, would I connect the switch between the positive and the signal wire or the negitive and the signal wire. Basically is power coming from the plc input or out of the input. I believe understand that when current drops to zero the plc input is actuated. My thought is that I connect the switch as normally closed and when actuated it would open providing zero current actuating the input. Any help would be appreciated.
