It will show the action either by letters (N.O./N.C) etc or a legend/diagram.
With a meter, you measure the continuity in the off state and then operate and show the relative contact closures.
Max.
So just to recap, If I have this right?
You originally have a common type of limit switch that has a NO & NC contact and you want to replace them with the toggle switches?
If so, the toggle switches have a different mode of switching to the L.S.
I have no idea what the controller expects as to inputs, but the bottom line is the toggle will not directly replace the switching action of the L.S.'s.
Max.
I would have expected a simple N.O. for each side, not sure why they include a N.C.?
Unless it was for some kind of interlock to prevent operation for any other switch.
Max.
Blue and white are just N.C. contact sense.
If the unit still operates, did you try to just use the C and N.O. input and see if the unit still functions without the N.C. input?
Just to see what the effect is, if any?
Also check the other operations simultaneously to see if any thing changes.
Max.
OK thanks for your help I think my next try will be to connect the blue and white like it is on my diagram (both ends of the switch) and putting the green wire (NO) in the middle of the switch and see what happens
