Replacing batteries in Electric Mobility Rascal 3-wheel scooter
Discussion in 'The Projects Forum' started by dhendry, Jul 21, 2015.
  1. dhendry
    Jul 20, 2015
    I put new batteries in the scooter but the negative wire doesn't reach the battery terminal. It has been 4+ years since I have worked on it and had the batteries out to prevent corrosion. I attached jumper wires to each battery but only the horn works. Do I also need to charge new batteries before use? I looked for a serial or model number but only found a small sticker under the frame.
    DH
