Replacing a switch with a mosfet
Discussion in 'Homework Help' started by jonnylazer, Apr 3, 2011.
  1. jonnylazer
    Jan 12, 2010
    17
    Hi all,
    im working on a circuit at the moment that requires some peak inrush current analysis.
    If you refer to the uploaded schematic you will see that the circuit has a 24 Vdc voltage connected across its output via a switch.
    What I want to do is replace the switch with a mosfet... how can I do this ?
    hope someone can help
  2. alexan_e
    Aug 8, 2010
    10
    You can use a Pmosfet, source to positive battery, drain as output and drive the gate with a voltage of about 12-14v to turn on (which would give a Vgs of 10-12v) or 24v to turn off (Vgs=0)
    Assuming that you are not goind to do switching in fast rate you can use a 10k resistor from source to the gate (pull up) to keep the mosfet off when no gate signal is present, and a gate resistor of about 1K to limit the gate charge current to about 10mA, you can use lower resistor if you can provide more current.
    Alex
