I'm hacking an mp3 player that has a pushbutton switch. The input pin of the chip
that senses button presses is normally pulled up to 3V. When the tactile button
is pressed the pin gets shorted to ground. I want to replace the mechanical action
of pressing a button with a signal from another circuit.
My control line switches from floating to ground when the event of interest
occurs. How can I make the mp3 player interpret this signal as a button press?
Is a capacitor between the input pin and the control line good enough?
Or would it be better to use a pnp in parallel with the pushbutton with control
line going to the base?
