Replacing a blown capacitor help
camochase
Joined Nov 17, 2013
6
I really don't know much about circuits especially capacitors. I over powered a circuit and blew a capacitor i hope it acted as a fuse and saved the board as a whole. But i wont be able to tell unless i replace the capacitor, but the casing around it identifying it is long gone. so is there a way for me to tell what kind i need? i think its 100uf 16v or 6v but thats a guess from memory so any tricks i should know? thanks for your help. if you need more information or a picture just ask and ill gladly post it
Alec_t
Joined Sep 17, 2013
14,313
A sharply-focussed close-up pic (.gif or .png) of the cap, and of the board area around the cap location, would help.
Mike33
Joined Feb 4, 2005
349
Yup. Also want to be sure it IS a cap. I've had someone think a cap blew when in fact it was an MOV on the primary of a transformer. What happened to cause the over-voltage situation?
DerStrom8
Joined Feb 20, 2011
2,390
Knowing what kind of circuit it is would also help a lot. What are the rated voltage inputs? How much voltage did you apply? What does the circuit do?
