Replacement transistor for SS8550
Discussion in 'The Projects Forum' started by inid_herath2007, May 18, 2010.
Thread Status:
Not open for further replies.
  1. inid_herath2007
    May 18, 2010
    can anyone pls give me a replacement transistor for SS8550....this transistor cant handle a higher voltage than 5V ...so i was hoping if i could find a transistor which can handle a higher voltage than this(maybe 9V+)
    (The transistor listed in here is the transistor I have)
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    A 2N2222A (NPN) or 2N2907A (PNP) should do the trick.
    inid_herath2007 likes this.
  3. inid_herath2007
    May 18, 2010
    It's an rc circuit i removed from a toy car...so would these replacements work fine with the other components?
  4. ajbaker
    Mar 10, 2016
    2n5401 will work nicely.
    TechHead
  5. GopherT
    Nov 23, 2012
    6,319
    4,043
    Just get the same transistor $0.24 plus shipping. Order 10 so you have spares if it happens again.
    This screen capture is from Digikey.com
  6. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    I've never seen a transistor for 5v max
    For radio circuit you should use the same type.
    Important is max permitted base current at which 5v never will be reached. The lowest ce breakdown I know is 20 volts for common kinds, reverse breakdown about 12v.
    You should specify which voltage you talk about
  7. Sinus23
    Member
    Sep 7, 2013
    178
    481
    OP was last seen in 2010 ;)
  8. GopherT
    Nov 23, 2012
    6,319
    4,043
    Wow, it took a long time to get some good answers to him. We are improving around here.
    Sinus23 likes this.
Thread Status:
