replacement or alternative diode
Discussion in 'The Projects Forum' started by ninjaman, Feb 13, 2015.
  1. ninjaman
    May 18, 2013
    306
    hello
    I want to build an antenna analyser I have the circuit and it calls for 4 aa143 diodes. I have looked at the data sheet and found that they are germanium and used in radio circuits.
    they are available only on ebay. I wanted to find something similar that was more readily available and cheaper. im not sure what to use though, I have tried OA91. I would like to use the ones in the circuit or closer. I don't know what is required though. should any RF diode be ok?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Do you have a schematic available?
    That way we can see how critical the diodes will be in the circuit.
    Bertus
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    schotkey diodes will probably work.
  4. wayneh
    Sep 9, 2010
    12,379
    3,232
    Cheaper and easier than e-bay? Good luck with that.
  5. Dodgydave
    Jun 22, 2012
    5,143
    768
    Try NTE110A, germanium diodes
    Reloadron likes this.
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Have a look at page 45 of the attached PDF.
    Bertus
  7. Reloadron
    Jan 15, 2015
    1,044
    268
    That should work as well as be available.
    Ron
