Replacement fuses don't work
Discussion in 'The Projects Forum' started by NathanielZhu, Oct 30, 2015.
  1. NathanielZhu
    Thread Starter Active Member
    Dec 5, 2011
    50
    I have a centrifuge that has an 8A 250V fuse that blew when I turned up the RPM to Max.
    So I went to microcenter and ebay to find a replacement fuse. The origional fuse does not indicate whether it was a fast blow or slow blow fuse so I decided to try both.
    I bought 8A, 250V fast blow fuse from microcenter and 8A slow blow fuses from ebay.
    Inserting either of these fuses and powering on the machine results in an instant spark and destruction of the fuse.
    just wth is going on? It makes makes no sense to me.
    The origional fuse had a different internal wire than the replacements but that shouldn't matter. It should be sold to perform as it is rated to perform but they don't.
    The origional had a glass fuse with a wire coiled around something white. The replacements were straight metal filament.
    Should I go up to 10A?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    The original fuse is slow blow.
    Unfortunately, if your machine blows a slow fuse just because you turned it on, the centrifuge is broken.
  3. NathanielZhu
    Dec 5, 2011
    50
    To be sure, could I power on the device by shorting the circuit without the fuse to test whether the device powers on or does the fuse provide any essential function like adding resistance aside from just blowing?
  4. #12
    Nov 30, 2010
    16,705
    7,358
    The fuse keeps the machine from going up in flames if it is really broken. Short the fuse AT YOUR OWN RISK!
  5. NathanielZhu
    Dec 5, 2011
    50
    haha. I'll tell you how it goes. If I don't post back- probably means I'm a pile of ashes.
    edit*
    Yeah you were right. A Capacitor caught on fire
  6. RichardO
    May 4, 2013
    1,350
    432
    Slow blow fuses look different than fast blow fuses. If both of your fuse types look the same I am guessing the slow blow fuses aren't.
    I don't think fuses normally say "slow" on them. Check for part numbers on both the original and the replacement slow blow fuses.
