Replacement for an old intersil IC
Discussion in 'The Projects Forum' started by ChrisChemist116, Aug 14, 2009.
  1. ChrisChemist116
    Thread Starter Active Member
    Mar 13, 2009
    78
    Hi, i was working with the following project http://home.scarlet.be/johnstaybank/dvm_3_digit.htm which is a voltmeter with 3 seven segment display interfase. But i found the ICs CA3161E and CA3162E are obsolete. Is there any equivalent replacement for both?.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
    I didn't check your link, but the most common 3x7 segment DVM's are made based on Intersil ICL7107 chip. Perfect for a cheap and fairly accurate DVM. You might need to follow the diagram in their datasheet though.
  4. ChrisChemist116
    Mar 13, 2009
    78
    Thanks for the advice on using the ICL7107. I made one (voltmeter) a couple of months ago using the schematic on the website cited at electronics-diy.
    But i particulary liked the version with CA3161 and CA3162 because it could be modified to be an ammeter with very few components as noted on (Sam's electronics http://web.archive.org/web/20080112...~athsam/digital_volt_and_ambere_meter_eng.htm) . I found that an ammeter could be made with the 7107 as seen here http://electronics-diy.com/ICL7107_digital_ammeter.php, but my classmates told me the schematic is wrong. I haven't tried but does that schematic seems wrong?
    And by the way Isn't there any way to find both outdated chips?.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There is. You can always get lucky and find them still offered by less mainstream electronic suppliers like Hosfelt Electronics or even Jameco (Jameco is getting up to a critical size, where the old stuff seems to fade away). Searching for surplus electronics stores can find all kinds of old IC's
    There are also warehouse operations that stock literally any old linear or digital IC. The problem is that you have to bid on lots, and the minimum seems to be $500.
    Here is a link to one of them - http://www.core-ic.com/catalog/I/I-121sum.htm
  6. Søren
    Sep 2, 2006
    472
    28
    Your classmates are wrong, not the schematic.
    The CA3161/2 is inferior to the ICL7107 in several ways. It has got half the resolution, less input protection and it tend to drift for a good while after turn on.
    ChrisChemist116 likes this.
  7. jj_alukkas
    Jan 8, 2009
    751
    5
    It is a fact that newer IC's are designed for better performance. Otherwise why would we upgrade a Pentium to Quad core rather than going back to a 486?
    I have built DVM's using ICL7107 and it is accurate if you calibrate it well. And any DVM IC can be modified to become an ammeter if it allows calibration. An no manufacturer wouldnt produce one without that function.
  8. Privateman
    Mar 7, 2010
    Sorry to pull down a senior member soren, but the 7660 bit of the diagram is wrong
    pins 3 and 5 are reversed, for the proper function
    your comment " Your classmates are wrong, not the schematic ", is wrong
    Rab:)
  9. atferrari
    Jan 6, 2004
    2,673
    785
    In two years, maybe he had time to change that...!
  10. Privateman
    Mar 7, 2010
    thank you atferrari
    bit insensitive to mention it, >>> Sorry
    Rab
