Can i use MUR160 in the place of MUR120 diode?. will there be any problem?
P Thread Starter pradeeba Joined Feb 27, 2008 104 Mar 17, 2009 #1 Can i use MUR160 in the place of MUR120 diode?. will there be any problem?
SgtWookie Joined Jul 17, 2007 22,230 Mar 17, 2009 #2 Did you look at the datasheet? The only difference between the two is the Vr. MUR120 Vr=200V. MUR160 Vr=600V.
P Thread Starter pradeeba Joined Feb 27, 2008 104 Mar 17, 2009 #3 If u see the datasheet max instantaneous fwd voltage is different, max instantaneous reverse current is different, max reverse recovery time is different, max fwd recovery time is different. if u observe the graphs also Vr Vs C also differs etc....
P Thread Starter pradeeba Joined Feb 27, 2008 104 Mar 18, 2009 #4 If i replace MUR120 with MUR160 diode is burning at 55DegC? why this is so?
SgtWookie Joined Jul 17, 2007 22,230 Mar 18, 2009 #5 Why don't you go back to the MUR120? Either that, or find out what else changed in the circuit.
