Sorry, didn't research further as I thought a ma was too much for you.Hi inwo,
the chip looks good, but i have to contact linear Monday for a replacement
It is obsolete, and nobody sell it
From what I've read, the gate voltage requirements for the ac-fets are quite high. That's why they often drive with led thru optic device.Hi inwo,
I will try Monday one of your circuits with a regular optocoupler
Using 2 fets in series i do not have to use the bridge rectifier, so will be no connection between the control to wires from furnace, nor the ground. I don't think that will work. The gate drive will still have to come from battery side.
I can leave with 10µA constant current taken by optocoupler
I will redraw the schematic and post it later
Thank for help to you and Alec
That's what I thought.it is from my power supply for the system 3.3Vdc
by Duane Benson
by Jerry Twomey
by Aaron Carman
by Jake Hertz
