Hi Fields,
I´m researching the 40103. It seems a good solution. Looking forward for the schematic.
Thanks a lot!
Thanks a lot!
Much of the text is to small to read. What are the timer chip part numbers?Anyway, a schematic for you follows.
Yeah, sorry about that . I'll fix it as soon as I can get to it.Much of the text is to small to read. What are the timer chip part numbers?
ak
If you want to use a chain of CMOS dividers - you could do worse than clock it with a 32.768kHz watch crystal.As i explained i dont have an osciloscope, and if i had this frequency i would have a different outcome.
In the meantime the counters are 40103s.
Fields isn´t this solution a little bit to much. I mean 4 CI and one clock generator. I like the idea to make the counting very precise and the possibility to display the counter with and extra CI and extra components. But then i come back to the idea you called nonsense, to use a micro-controller.
As i recall, my comment regarding your content being nonsense was predicated on your total confusion with regard to asking a question which would yield something other than noise as an answer.
So far, you've progressed to the point where you've stated that you can live with an error of a second or two out of the 180 second short count timer, which is a step in the right directon.
Also, as I recall, you originally stated:
"This can be set very easily with a microcontroller, but for sake of parts and knowledge i want to try to make this with analog. Also, managing analog real-time time set with microcontroller can be tricky with potentiometer, which would lead to a complex case of HMI"
All total nonsense since you don't know what you're talking about, and what you're hoping for is that someone will give you a clue that you don't have to pay for in terms of face.
Also, with a 16Khz crystal and one counter it is possible to assemble a very precise clock.
Well, i will play around the concept for learning purposes.
How would you get 1 second clock out of a 16 kKz oscillator?Fields isn´t this solution a little bit to much. I mean 4 CI and one clock generator. I like the idea to make the counting very precise and the possibility to display the counter with and extra CI and extra components. But then i come back to the idea you called nonsense, to use a micro-controller.
The refusal to use one was yours, not mine.
Indeed, but you've posted only opinon and haven't show the circuit required to prove your point .
It's fixed.Yeah, sorry about that . I'll fix it as soon as I can get to it.
http://www.hackersbench.com/Projects/1Hz/How would you get 1 second clock out of a 16 kKz oscillator?
You wrote: "Also, with a 16Khz crystal and one counter it is possible to assemble a very precise clock."
