KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
Take a look at the CSS555 timer http://www.customsiliconsolutions.com/downloads/Revised Standard products/CSS555_Spec.pdf , available from Jameco. It will likely require the "programmer", but can remove the yucky long-term timer interval performance of a real 555.
www.picaxe.com (processor) might be simple enough for you to use. 0-100% (potentiometer with a voltage reference) can easily be based on an A/D converter.
