Hello, people of this forum! I'm new here!
I'm in need of help to repair an old cassette player that's been laying in my attic for several years. When you turn it on it seems working and everything; it even plays the cassette quite well (it does play some noise too, but I think it only needs demagnetisation), untill, in just a few seconds, the tape starts tangling up. I tried polishing the heads and yes, they were horribly dirty, but cleaning them up to perfection didn't solve the problem. The "receiving" gear (I hope you get what I mean) won't spin at all when playing the cassette and it will barely catch up when fast forwarding, so I thought it's obvious that there is some problem with its motor. Only, I searched the schematics (http://freeservicemanuals.info/en/servicemanuals/download/Philips/n2233.pdf) and it appears that there is just one motor for both gears. So my question is:
Thank You!
- Can anyone of you understand if the problem described could be related to the motor? Basically, if it turns out that there is only one motor input, it probably means that it is the mechaninsm transmitting and transforming this input to be malfunctioning.
- If the motor is the source of the problem, can someone somehow desume the characteristics of this motor from the schematic so that I could replace it?
- Any other idea about what component could cause the problem? Becouse it really looks electronical rather than mechanical.
Thank You!
