bwilliams60
- Joined Nov 18, 2012
- 1,442
Personal choice. You don't need it but nice to have around.
Too little....too late. If you read post #26, the OP has repaired the set already.So its LG.....eehh??.the old good time problem....no video !!! are you using 75 ohms aerial cable direct on your set?
If yes you had a bad video tuner (its a BIG mess tryin to solder/disolder, i believe me you loosing your time),try to connect a DTV and use the 3x RCA cable (VIDEO/AUDIO L/R) to the recpective inputs. Don't forget to select your source (i.e Aerial, AV, HDMI etc.)
Try it and you will remember me.
I know that you had repair your set and its good for you, that you had try and fix it your own.Too little....too late. If you read post #26, the OP has repaired the set already.
Thread starter | Similar threads | Forum | Replies | Date |
U | Help repairing RC board | Technical Repair | 5 | |
M | Need help repairing Vevor KZ-SZM 15 mixer | Technical Repair | 1 | |
S | Repairing car stereo | Technical Repair | 8 | |
K | Repairing my Asus tuf 180w laptop adapter, it's suddenly stopped working | Technical Repair | 3 | |
C | Need help repairing thermoelectric cooler | Technical Repair | 8 |
