repair broken wire in 2N6308
Discussion in 'General Electronics Chat' started by mostafa_gordy, Dec 26, 2012.
  1. mostafa_gordy
    Feb 28, 2012
    57
    hi ...
    how to repair broken wire in this 2N6308 Motorola Transistor ?(regular soldering is ok or no?
  2. kubeek
    Sep 20, 2005
    4,687
    805
    I think those wires are aluminium, so you will have a very hard time repairing that. Why don´t you just get a new one?
    And as you can see, one learns through his errors :)
  3. mostafa_gordy
    Feb 28, 2012
    57
    FOR recreation
    you what is think
    ink part number is easy cleareing! by hand sweat?!
    is not fake:confused::eek:
  4. kubeek
    Sep 20, 2005
    4,687
    805
    If you´re asking if it´s fake or not, I frankly have no idea. You can try ordering another from farnell or digikey to get something to compare.
    Anyway, for 125W that die looks pretty small, and if the numbers go off very easily, then it might be fake.
  5. spinnaker
    Oct 29, 2009
    5,065
    1,173
    What???
    Time to get a better translator software.
  6. absf
    Dec 29, 2010
    1,493
    374
    Transistor Polarity:NPN
    Collector Emitter Voltage V(br)ceo: 350V
    Transition Frequency Typ ft: 5MHz
    Power Dissipation Pd: 125W
    DC Collector Current: 8A
    DC Current Gain hFE: 60
    Transistor Case Style: TO-3
    Collector Emitter Voltage Vces: 5V
    Current Ic Continuous a Max: 8A
    Hfe Min: 3
    Package / Case: TO-3
    Or get a substitute. It costs more than $5 in single quantity in Farnell (element 14).
    Allen
  7. mostafa_gordy
    Feb 28, 2012
    57
    if repair transistor better for me iam not rich similar to.
    i use 2n6308 for Transistor Ignition !(by Darlington circuit)
    bux15 is substitute 2n6308
    or ......
  8. MrChips
    Oct 2, 2009
    12,624
    3,451
    You cut open a TO-3 can to repair a power transistor?
    That must be the first I have ever heard of.
  9. crutschow
    Mar 14, 2008
    13,479
    3,366
    I'll probably regret asking this, but why would anyone cut open a transistor and then expect to use it? :confused: Transistors are sealed for a reason.
    And no, the wire can't be soldered.
  10. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    NEVER open any transistor, as they MAY contain beryllium oxide, wich is carcinogenic when made to dust.
    http://en.wikipedia.org/wiki/Beryllium_oxide
    Even small amounts that entered the body can lead to death over time.
    Bertus
    PackratKing likes this.
  11. mostafa_gordy
    Feb 28, 2012
    57
    if me connect broken wire = Transistor will working fine ??
  12. MrChips
    Oct 2, 2009
    12,624
    3,451
    Very unlikely. Why was the wire broken? Because you tried to cut the case open.
    The transistor was bad in the first place.
  13. nigelwright7557
    May 10, 2008
    488
    71
    If the wire has fused then the transistor is most likely dead anyway.
  14. mostafa_gordy
    Feb 28, 2012
    57
    I use in Ignition Circuit (Darlinton mode)
    circuit is false install....
  15. mostafa_gordy
    Feb 28, 2012
    57
    wire is not melt and silicon chip is looks good (clear ) ...?
  16. spinnaker
    Oct 29, 2009
    5,065
    1,173
    Just because it "looks good" does not mean it is good. It was not designed to be opened. Even if it was working when you opened it, it won't work anymore. At least not for very long. You need to buy a new component. I'm sorry you cannot afford it.
