Renovate a logic system...
Discussion in 'Embedded Systems and Microcontrollers' started by andrewking, May 12, 2007.
  1. andrewking
    May 12, 2007
    I want to renovate a logic system into a micro based board. I would like to use c and write some code on Xcode(OS X). I am looking to find a simple chip to start on may be 12-18 inputs, 10 outs or so. I have someone to help me get going with the language to get my feet wet, but will likely do some consulting to speed up the curve. If you've used a specific chip and have a part number you like that would be great
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Can you provide more detail into the function performed by the old logic system? A schematic would be very helpful.
    There are several microcontrollers that could be used but it would be premature to recommend anything specific without more information.
    hgmjr
  3. n9352527
    Oct 14, 2005
    1,198
    Correct me if I'm wrong, but isn't Xcode only produces OSX binaries? You'd need development tools specific to the microcontroller that you'd choose, which you should do first.
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Thats how I understand it.
    The OP needs to select a suitable microcontroller for their application.
    Dave
  5. andrewking
    May 12, 2007
    thaks for your information...
