Renaming a I/O port
Discussion in 'Embedded Systems and Microcontrollers' started by Eric007, Aug 26, 2011.
  1. Eric007
    Thread Starter Senior Member
    Aug 5, 2011
    1,054
    33
    Hi All
    Is it legal to give a I/O port 2 names?
    For example:
    LEDPORT equ PORTA
    SWPORT equ PORTA
    The reason I'm asking this is that I have defined some pins as input and some other pins as output in the same PORTA
    Any comments would be appreciated
    Eric007
  2. ErnieM
    Apr 24, 2011
    7,435
    1,625
    Nope, that is not a problem at all for the assembler.
    If it makes more sense for the person writing the software then by all means do so. Symbol names are much better then magic numbers as they are self-documenting.
  3. Eric007
    Aug 5, 2011
    1,054
    33
    Thanks alot ErnieM!!!
  4. nigelwright7557
    May 10, 2008
    488
    71
    I use the define keyword for ports.
    #define ERRORLED PORTA,1
    I then dont care what port or pin it is on.
  5. Eric007
    Aug 5, 2011
    1,054
    33
    @nigelwright7557: Ok!
