Removing voltage spike from kiln controller
Discussion in 'General Electronics Chat' started by Mike Pickering, Apr 29, 2015.
  1. Mike Pickering
    Apr 29, 2015
    5
    Please could somebody help an electronics novice!
    I am building an electronic controller for my pottery kiln; basically it is a mains powered PID temperature controller that operates solid state relays to turn on/off and regulate the high current load to kiln elements.
    There are two temperature controlled (settable) alarm outputs on the PID that service low current relays which are used to feed simmerstats where the loads provide an alternate feed to the solid state relay. The purpose of the simmerstats is important to ramp the kiln loading in set stages. In principle the logic works fine.
    The difficulty that I am having is the load to the simmerstats produce voltage spikes as the bimetallic strips make and break and these spikes are upsetting the PID. I've tried putting 470pf ceramics across the simmerstat feeds and that has perhaps improved things a little but not solved the problem.
    Could anybody help me with a better solution? Thanks
  2. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    First off are you certain your problem is indeed 'glitching' secondary to transients (as opposed, for instance, to 'bounce')?
    Assuming the difficulty owes to transients you may wish to consider implementation of MOV{s}...
    If, on the other-hand, the problem is issue of contact bounce and you do not have write access to the firmware, a satisfactory hardware solution is signal 'scrubbing' via a one-shot...
    Best regards
    HP
    Reloadron likes this.
  3. Reloadron
    Jan 15, 2015
    1,055
    275
    Something you can try, rather than just a capacitor across the switch contacts is a "RC Snubber" circuit.
    A Google will bring up formulas for the values of R and C. Driving a resistive load like heating elements this should not be a problem. I see where you mention:
    Anything across the relay coils like a few flyback diodes? Also with good PID control in a kiln I don't understand the need for simmerstats but kilns aren't my forte either. :)
    <EDIT> I see Hypatia's Protege is up and about this morning. :) </EDIT>
    Ron
    Johann and Hypatia's Protege like this.
  4. Hypatia's Protege
    Mar 1, 2015
    2,850
    1,317
    Indeed! Addition of a dissipative element may well 'do the trick' :D
    Best regards
    HP
  5. cmartinez
    Jan 17, 2007
    3,700
    2,799
    At what voltage does your kiln operate? You could install a TVS diode in series with a high capacity resistor, and place those components at the simmerstats feeds. That could help you get rid of those spikes
  6. Mike Pickering
    Apr 29, 2015
    5
    Thanks, No I am not certain but think it correct; I have fitted a permanent voltage and current measure device on the overall input to the device in preparation for when I connect in the elements and what I observe is the voltage and current spiking "in tune" with the clicking that I can hear from the simmerstats and at the same point that happens the readings on the PID display go awal.
  7. shortbus
    Sep 30, 2009
    4,097
    1,695
    Don't know much about the size of your kiln, but when still working our small heat treat oven (basically a kiln) used mercury relays, because of 'point bounce' on mechanical relays.
  8. Mike Pickering
    Apr 29, 2015
    5
    Thanks, yes I will try this. I have ordered a selection of higher voltage ceramics of different value and will also try adding a resistance as you suggest. Is this best on the live or the neutral side of the capacitor or does it not matter. I'll explain the reasoning for needing simmerstats to the response from Max below.
  9. Mike Pickering
    Apr 29, 2015
    5
    Thanks, Everything runs at 240V; not really sure I understand as my electronics is fairly fundamental. I'll look up TVS diodes on google and see if it makes more sense to me.
  10. Mike Pickering
    Apr 29, 2015
    5
    Thanks, You need to ramp a kiln so for example you may want to heat the first 100C very very slowly with a 10% energy cycle which will take several hours, 100-350 can be ramped a bit quicker so you perhaps give it a 50% energy cycle. 350-1200 you might want it to go as quick as you can so you have it full on until it reaches 1200 at which point you want it to dwell (maintain temperature) for say an hour and then switch off.
    The way I have set it is the turn on position operates from the first simmerstat until the first warning switch in the PID is triggered this sets conventional relays turning off the first simmerstat and turning on the second simmerstat this will then continue to heat until the second warning switch in the PID is triggered which again sets relays turning off both relays and instead using the standard PID heater feed.
    The PID does have an energy regulation function but it is just one setting which would mean that I would have to be there and manually reset the PID each time I want to change the ramp rate which would not buy me anything. I did for a while consider buying multiple PID's but this seemed over the top; I may though have to go back to this idea if I can not get old simmerstat technology to work along side present day PID tech.
  11. Reloadron
    Jan 15, 2015
    1,055
    275
    I had a feeling this was about the ramp. What would be cool is a nice controller with ramp and soak features where you can for example say go to 200 F and take 3 hours to to it. Remain at 200 for 1 hour (Ramp and Soak). Then go to whatever and soak... :) . Anyway, give some of the suggestions a shot and see if they don't clean things up.
    Ron
  12. ian field
    Oct 27, 2012
    4,459
    792
    The TS's capacitor would've stopped the spikes if it had been a fair bit bigger than 470p, but each time the contact closing coincides with the crest of the AC wave - the contacts go "splat"!
    The resistor in your snubber diagrame is absolutely vital.
